#99836 - 09/23/0312:29 PMRe: 10.2.8 - a LOAD of problems!
[Re: MacGizmo]
walzuhair
Smudgaholic
Loc: Riyadh, Saudi Arabia
The only problem I encountered so far is iSync with my SonyEricsson P800 over Bluetooth. iSync cannot see the P800, but Bluetooth works OK since I can exchange files between it and the Mac.<br><br><br>DigitalEye
And I did the exact opposite. I downloaded and installed while simutaneously surfing and chatting on iChat. And it's smooth sailing <br><br>My stuff for sale.
I guess I should say for the record that I ran the software update on my iBook while surfing the net last night and other than Transparent Dock not working, everything went smooth. I haven't installed it on my tower yet, but I'm sure it'll be fine. I will be using the Combo update to upgrade my tower.<br><br>
#99841 - 09/23/0306:04 PMRe: 10.2.8 - a LOAD of problems!
[Re: MacGizmo]
No problems with the update here, either. I'm running Repair Permissions right now as I type this--no black screen. My ethernet is working fine. I have Clear Dock, and that's still functioning, as are the other haxies I have.<br><br> Alas, poor Yorick. -- Hamlet
