Just got the old (802.11b) base station of my mom's and I tried to get it working. The card in my PB recognized it but I didn't know the password. My mom can't remember it either but she said it was public. I've tried that and every other possible password she uses.<br><br>I got a great suggestion to just reboot it so I did. Got directions to directly connect the base to the PB with an ethernet cable, redid the TCP configuration, pressed the reset button....everything. <br><br>I got to the point where my Airport Asst was scanning for stations and couldn't find mine. It still won't. It will when I remove the cable from the station and plug it back into the cable modem (box). But then it continues to ask for a password. AAAARGH!<br><br>help!<br><br>
PointBreak
addict
Loc: Australia
Lisa I would love to help but I am not an airport user but I know how lonely it is to post and have no replies. So to make sure you feel loved here is a reply <br><br>Need a laugh? Visit CreatorDude.com
I forget what the default password is, but I have an Airport Extreme basestation at home. I'll look in the manual when I get home.<br><br>If after that, it still doesn't work, hold down the reset button for five seconds, it will erase all settings. Then put them in again and try again.<br><br>
Morom
addict
Loc: Chicago, IL
This should help<br><br>http://docs.info.apple.com/article.html?artnum=50892<br><br>----<br>A computer without a Microsoft operating system is like a dog without bricks tied to its head.
---- Stupidity is like nuclear power. It can be used for good or evil.... and you don't want to get any on you.
Thanks! Will try that. At the rate I'm pressing down on that reset button, I'd better get some sort of connection. It pains me that I have a fully functioning Airport base station and I can't get it work!<br><br>
