Loc: Los Angeles, California, USA
100.0.0.lx looks like a class a network, which I don't think he is running. It depends on how the network is set up. You may want to look at the PC configuration, in a dos window run ipconfig /all..<br><br>You should see the DHCP server, the DNS server, net mask, default gate way and the IP address. This information should be helpful in setting up your Mac.<br><br>
_________________________ Life isn't about waiting for the storm to pass, It's about learning to dance in the rain!
Loc: New Hampshire
there are several private IP ranges assigned by IANA<br><br>10.x.x.x<br><br>172.16.x.x to 172.31.x.x<br><br>and 192.168.x.x<br><br>these are used for local area networks and are not routable on the internet. If you have an IP address outside this range you are either connected right to the Internet with a static IP address assigned to you or (as in this case) you have completely misconfigured your local area network.<br><br>there is another range<br><br>169.254.x.x<br><br>which is auto configuring range. PCs without a DHCP server and set to dynamic IP will assign themselves a random IP address in this range. So if you ever see your computer assigned a number in this range, chances are you either have no ethernet connection or the DHCP server is not working.<br><br>[color:blue]My only goal in life is to live forever - so far so good!</font color=blue>
Loc: New Hampshire
"We use Windows 2000 server with Service pack 3 & exchange Server 5.5 with Service Pack 3"<br><br>looking to get infected with the Blaster virus?<br><br>tell you IT guy to put the latest service pack and patches on.<br><br>[color:blue]My only goal in life is to live forever - so far so good!</font color=blue>
