greenme1
Loc: Pittsburgh, PA
On my site there are 4 frames and when you resize the window (horizontally) the middle and top frames expand. Is there a way to have all of the frames static in size and have a background that would get bigger instead, and how would you do that? I would like an effect similar to the MM front page.<br><br>"If everything seems to be going well, you have obviously overlooked something. "
Loc: New Hampshire
to keep the frames the same size and have it centered you need 3 frames<br><br>left | center | right<br><br>set the center frame to 600 pixels in width, and set the left and right one to 50% <br><br>
I would go easy on the frames if I were you...any more than two and you're asking for problems..<br><br>Try a frameless solution to your problem if it's possible...<br><br>[color:red]DaddyMac's MP3 to AAC conversion: left to go...</font color=red>
greenme1
Loc: Pittsburgh, PA
I would rather have a bloated, barley functioning, and slow loading website. That way i can keep the anticipation up while it's loading or when there trying to navigate my site but just can't get there because of the horrible layout. <br><br>"If everything seems to be going well, you have obviously overlooked something. "
So you have plans to work for Microsoft at some point, eh?<br><br><br><br>Great wits are sure to madness near allied.--John Dryden, "Absalom and Achitophel"
You should rather use tables rather than frames for several reasons:<br>1. Frames load slower<br>2. Frames need one separate html and a main html, so it's complex<br>3. Frames can't be read by search engines properly<br>4. Some browsers have problems displaying frames<br><br>I used to prefer frames, but since I started using tables, I'd never go back unless there is really no other way to solve a layout.<br><br>
greenme1
Loc: Pittsburgh, PA
Ok, I guess I'll take the Pro's advice (that includes you DM). <br><br>Here is the 4th version of my site, this time using tables instead of frames:<br><br>http://homepage.mac.com/greenme1/Alex's Page v4/index.html<br><br>"If everything seems to be going well, you have obviously overlooked something. "
greenme1
Loc: Pittsburgh, PA
So far the only major problems are the sporadic change in visited link colors, and an overall lack of content. But i plan to fix both of them in the near future. <br><br>"If everything seems to be going well, you have obviously overlooked something. "
Oh sure, you listen to Ivan when he tells you 'no frames', but me you choose to mock, huh?<br><br><br><br>[color:red]DaddyMac's MP3 to AAC conversion: left to go...</font color=red>
