Pages 4.04 #647742 10/31/18 08:43 AM
keymaker Offline OP
I invented modding!
I invented modding!
Is there a way of getting Pages 4.04 to work in Mojave 10.14?
km
Re: Pages 4.04 [Re: keymaker] #647758 11/05/18 02:17 PM
Reboot Offline
From what Iíve seen there is not a fix. It appears you can throw away the plist file and it will open a document the first time, but after the first one it wonít open any anymore. I donít think it will even create one will it?
Whatís the reason you do not want to upgrade?
Re: Pages 4.04 [Re: Reboot] #647801 11/11/18 10:22 AM
keymaker Offline OP
I invented modding!
I invented modding!
Thanks Reboot. The main reason is that text and formatting is scrambled on opening some of my older docs with 7.3 but I also got used to the interface with 4.04 so I'm a bit faster with it. For some reason Apple has kept 4.04 in place on the system even though one can't actually do anything with it...
km
