Mojave #647587 10/05/18 03:08 PM
B
billwhit1 Offline OP
B
I was looking around and I find lots of duplicates files and applications.if you go to system report then down to software then down to applications wait and this lists all 64 bit and other applications. Many duplicates same version same date. by clicking on the bits column it will separate 64 bit and other. I see many duplicates. Is it save to remove all duplicates with same version, same date, same length. ?
Re: Mojave [Re: billwhit1] #647595 10/06/18 07:57 PM
Reboot Offline
Is the file path the same for the dupes?
