Page 1 of 2 1 2
‘Variety-dot-com! #647452 09/09/18 09:17 PM
M
Mike Offline OP
Mr Zig
Mr Zig
M
Lately any website I go to with Safari will -after a few seconds- will surprise me with a ‘pop up’ notifying me that I have ‘won’ something, either from Walmart or from Amazon. I’m using the Safari ‘pop up block’ feature, but it still comes up. I also clear any web data. When I checked under ‘Advanced’ I find web data from ‘Variety.com’ . It seems impossible to get rid of this. These annoying pop ups do not occurr when using any other browser , like Chrome, Firefox, or now Edge. Is this a virus?
Re: ‘Variety-dot-com! [Re: Mike] #647453 09/09/18 09:42 PM
Reboot Offline
Look in Extensions in Safari Preferences. What is listed there?
Also download and run Malwarebytes.
Re: ‘Variety-dot-com! [Re: Reboot] #647454 09/09/18 10:27 PM
M
Mike Offline OP
Mr Zig
Mr Zig
M
It also appeared on Safari on my iPad!
Re: ‘Variety-dot-com! [Re: Reboot] #647455 09/09/18 10:31 PM
M
Mike Offline OP
Mr Zig
Mr Zig
M
The only extension listed is from 1Password. And that’s never caused any problems.
Re: ‘Variety-dot-com! [Re: Mike] #647456 09/09/18 11:36 PM
Reboot Offline
Re: ‘Variety-dot-com! [Re: Mike] #647457 09/10/18 12:02 AM
Reboot Offline
I've seen this on my iPhone. The spinning 'Amazon wheel you won' BS. Does it happen with the same frequency on the iPad?
What happens is these poisoned ads get injected into a perfectly legit web site's ad rotation, the web site realizes it, then they get rid of it but it may take a while. For example I use http://wordplays.com for my crossword hints because it is lean and mean. They have few ads but not much. I never use it on the Mac, just my iPhone. A while back sometimes when I'd go there it gave the Amazon BS. It went away a few months ago.
Maybe it's some site you go to on both the iPad and Mac?
Re: ‘Variety-dot-com! [Re: Reboot] #647458 09/10/18 12:38 AM
M
Mike Offline OP
Mr Zig
Mr Zig
M
“Maybe it's some site you go to on both the iPad and Mac?”—
Hmm......From Huffington Post? Never had problems there before.... crazy
Re: ‘Variety-dot-com! [Re: Reboot] #647459 09/10/18 01:09 AM
M
Mike Offline OP
Mr Zig
Mr Zig
M
Since it doesn't 'pop up' in either Chrome and/or Firefox and Edge, perhaps it's a Safari 'vulnerability'? cry
Re: ‘Variety-dot-com! [Re: Mike] #647460 09/10/18 02:33 AM
Reboot Offline
Amuse me. Install and run Malwarebytes. If that doesn't find anything we'll go from there.
Re: ‘Variety-dot-com! [Re: Reboot] #647461 09/10/18 12:23 PM
M
Mike Offline OP
Mr Zig
Mr Zig
M
Installed it.....so far, so good!
But, no matter how many times I clear all web data, this stupid ‘variety.com’ web addy cannot be cleared.
It doesn’t seem to contain any data (indicator says zero data),but it’s still there even though I deleted it several times. Everything else ‘clears’ out just fine..... mad
Page 1 of 2 1 2
