Lightning dock #641225 09/08/16 09:20 PM
NucleusG4 Offline OP
Master•Blaster
Master•Blaster
For anyone freaking out about how they are going to charge their phone whilst listening to music with wired headphones.. here's the $39.00 answer.
http://www.apple.com/shop/product/MGRM2AM/A/iphone-lightning-dock-white
Re: Lightning dock [Re: NucleusG4] #641274 09/11/16 01:12 AM
Reboot Offline
Meh, too big and bulky unless you only want to use it at home on a table/desk. If you want to charge the phone and listen to music you can't just hold it, set in your lap or whatever. Someone needs to make a smaller Y connector to split the power and the sound.
Anyway, without the audio port on the phone how does one go somewhere and connect their phone audio to a home sound system for example? How many stereos do you know that have bluetooth?
No sir, I don't like it, getting rid of the port stinks.
Why don't you get a 7 and sell me your 6? laugh
Re: Lightning dock [Re: NucleusG4] #641275 09/11/16 02:18 AM
six_of_one Offline
Pool Bar
Pool Bar
Well, you could use this I guess, although it's still clunky. And, of course, if you wanted to use your non-lightning wired headphones, you'd have to use the Apple lightning-to-stereo-minijack adapter included with the phone -- so that's an adapter plugged into an adapter =P
Yeah, not really digging that either, although I suppose it's "the future" -- I'll still probably end-up getting one, though =P
Re: Lightning dock [Re: Reboot] #641303 09/12/16 03:04 PM
Master•Blaster
Master•Blaster
You're old and out-of-date. grin
The new tvs allow you to connect directly to them which feeds to your stereo.
Or you have Apple TV.
Re: Lightning dock [Re: NucleusG4] #641304 09/12/16 03:05 PM
Master•Blaster
Master•Blaster
In another 5 minutes there will be cases that split it for you and have 2 connectors.
Re: Lightning dock [Re: NucleusG4] #641305 09/12/16 05:32 PM
Reboot Offline
My RCA CRT doesn't have USB. cry
Re: Lightning dock [Re: NucleusG4] #641306 09/12/16 05:33 PM
Reboot Offline
Re: Lightning dock [Re: Reboot] #641307 09/12/16 06:16 PM
Master•Blaster
Master•Blaster
USB?
You so funny.
Airplay.
https://support.apple.com/en-us/HT204291
Even my daughter knows this. She thinks it's funny to pre-empt my program with her iPad from the bedroom with some silly YT vid. smile
Re: Lightning dock [Re: NucleusG4] #641314 09/13/16 04:03 AM
Reboot Offline
Airplay? Never heard of it. Thx.
tongue
The Apple ecosystem integration is not my point though.
Re: Lightning dock [Re: Reboot] #641317 09/13/16 11:34 AM
Master•Blaster
Master•Blaster
I guess it's just like everything else Apple has done that we had to get used to.. it's a work-around at first, then it becomes the norm. I remember having to transfer data via a USB stick to another computer in order to burn a disk cuz the one I was on didn't have on.
On another note.. we went from vinyl to cd's to mp3s and now we are expected to like BT. Next phone will have a string and an soup can. The string has to be held tight in order to work properly. I can just see it now for all the people that complain it doesn't work... Apple will just say...
"You holding it wrong". laugh
