Unwanted Mailbox? #638541 04/11/16 04:36 AM
Acumowchek Offline OP
Is this thing on?
Is this thing on?
I just noticed a Mailbox located on the sidebar of my work account.
I did not add this, and it says I can't delete it.
What in the world is this, and how did it get there?
Re: Unwanted Mailbox? [Re: Acumowchek] #638546 04/11/16 10:39 AM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Re: Unwanted Mailbox? [Re: Acumowchek] #638547 04/11/16 12:10 PM
Reboot Online Content
Online Content
Carnac the Magnificent has tried, but he can't figure out what version of OS X you're running or if it's IMAP or POP.
If you're using the junk mail filter try turning it off then quit and restart mail for starters.
Re: Unwanted Mailbox? [Re: Reboot] #638551 04/11/16 01:50 PM
Is this thing on?
Is this thing on?
Thanks David, I'll give it a read,
Oh, Mighty Carnac, I'm running the latest and greatest, of course. wink
OS X 10.11.4 with IMAP Mail. The mail accounts are hosted through a company called Sage.
Thanks for the help.
Re: Unwanted Mailbox? [Re: Acumowchek] #638552 04/11/16 04:56 PM
Online Content
That link is about setting spamassassin up on OS X server, but it leads in the right direction.
Maybe the provider has changed their filters and it's in a learning phase.
You never replied cry but if you tried turning Junk Mail off on your machine and it's still there and you can't delete it I'd say just give it some time, Sage will probably fix it.
Re: Unwanted Mailbox? [Re: Reboot] #638553 04/11/16 05:19 PM
Is this thing on?
Is this thing on?
I'm sorry, had to take care of business first.
Yes, I tried turning off the junk filter, but it didn't work.
I called Sage, and (hopefully) they will return my call soon.
I'll let you know…
Thanks, Jim.
Re: Unwanted Mailbox? [Re: Acumowchek] #638560 04/12/16 02:47 AM
Is this thing on?
Is this thing on?
Update: No answer from Sage. tongue
Re: Unwanted Mailbox? [Re: Acumowchek] #638562 04/12/16 03:51 AM
Online Content
Give it a few days. Probably just disappear.
Re: Unwanted Mailbox? [Re: Reboot] #638568 04/12/16 02:38 PM
Is this thing on?
Is this thing on?
Yeah… It doesn't appear to be anything to worry about. (Famous last words). wink
