Jumper Settings ATA/ IDE #637585 02/19/16 08:22 PM
Offline OP
I invented modding!
I invented modding!
I never created an External HHD
(I'd only bought them ready to Plug N Play)
In spite of 2 days of research, I figured
since it was the only FW400 External Drive,
MASTER(SINGLE) would be the Jumper Setting.
but when I tried plugging it in, there are
NO Signs of Life - no Power/light indication
..and it don't show up in System Profiler
when I search System Profiler.
It also doesn't show as a DRIVE In DISK UTILITY
When I reattach my FW400 DVD Burner, it works.
The DVD Burner Does Show in Both DU & Profiler
QUESTION:
Doano if the issue is the JUMPER SETTING, since
the FW400 shows up as feeding off the INTERNAL BUS
so... Should I have chosen SLAVE???
Or did I install it incorrectly? Miss a connection
OR IF THE USED/PULLED DRIVE IS BAD
BTW:
Since the new(used) HDD is a recent acquistion
there's a limited window in which to TEST &
RETURN It for a refund ASAP. frown
____
[Linked Image from animatedimages.org]
[Linked Image from hosting.photobucket.com]
Re: Jumper Settings ATA/ IDE [Re: ] #637586 02/19/16 08:31 PM
Reboot Offline
It should be Master. What make and model is the drive?
Re: Jumper Settings ATA/ IDE [Re: ] #637587 02/19/16 08:41 PM
Offline OP
I invented modding!
I invented modding!
umm I also made the mistake of installing it
into the External Drive Enclosure without
double checking the FORMATTING... blush
I'd assumed being the model # ends with "A"
that it was naturally formally used in anApple Product...
I plead Stupidity.. crazy
I haven't installed a drive in years...
...I pretty much had to start learning again
on the fly from scratch
____
Re: Jumper Settings ATA/ IDE [Re: ] #637588 02/19/16 08:44 PM
Reboot Offline
That doesn't matter, Mac can read anything, it should show up. It can be formatted also.
Re: Jumper Settings ATA/ IDE [Re: Reboot] #637589 02/19/16 08:48 PM
Offline OP
I invented modding!
I invented modding!
Seagate/Barracuda 7200.10 SATA
3.0Gb/s 500-GB Hard Drive
ST3500630A E
ATA/IDE
16MB
I May be wrong about it being a SATA Drive..
..it has FIVE Rows of Jumper OPTIONS
____
Re: Jumper Settings ATA/ IDE [Re: ] #637590 02/19/16 08:52 PM
Reboot Offline
That's an IDE.
Re: Jumper Settings ATA/ IDE [Re: ] #637591 02/19/16 08:53 PM
Reboot Offline
For a single drive in a case it should be Master.
Re: Jumper Settings ATA/ IDE [Re: Reboot] #637594 02/19/16 09:27 PM
Offline OP
I invented modding!
I invented modding!
That's what I chose..
guess it's time to crack-it-open
to see where I zigged instead of zagged
crazy
____
