Page 1 of 3 1 2 3
OS X Font management #637376 02/11/16 02:43 AM
Acumowchek Offline OP
Is this thing on?
Is this thing on?
How do I prevent apps (I'm looking at you, Adobe & Apple) from installing all the foreign language fonts every time I update? I don't want 'em, I don't need them, and I'm tired of having them in my font menus. mad
Re: OS X Font management [Re: Acumowchek] #637383 02/11/16 11:03 AM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Re: OS X Font management [Re: NucleusG4] #637384 02/11/16 11:08 AM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Also, Cocktail is a great utility app and has the option to remove languages. It's $20.00
Re: OS X Font management [Re: NucleusG4] #637385 02/11/16 11:10 AM
NucleusG4 Offline
Master•Blaster
Master•Blaster
When unregistered, Cocktail runs in demo mode and will expire after the tenth launch. If you like your Cocktail, please purchase the license from our resellers, Kagi or eSellerate.
http://www.maintain.se/cocktail/
Re: OS X Font management [Re: NucleusG4] #637387 02/11/16 01:26 PM
Reboot Online Content
Online Content
I don't recommend doing that. Using those programs has been known to fubar the system. I also don't think it's going to solve his problem.
It also doesn't really save that much disk space. I would bet it would only trim it by 3 gigs or so.
Re: OS X Font management [Re: Acumowchek] #637388 02/11/16 01:31 PM
Online Content
Do you mean the Asian fonts?
Read this before messing with fonts. They have a downloadable PDF for OS X.
Re: OS X Font management [Re: Reboot] #637389 02/11/16 02:41 PM
Is this thing on?
Is this thing on?
Yes, I meant fonts only, not the Package Resource files.
I'm kinda OCD when it comes to font management, and I like a clean machine. HD space has nothing to do with it.
So many Asian fonts are now "System" fonts, that require authorization, and it becomes a pain to get rid of them. Seems like after every update or upgrade, they are all reinstalled.
Re: OS X Font management [Re: Acumowchek] #637391 02/11/16 03:35 PM
Online Content
Read that Font management guide. Some of those fonts should not be removed because the system needs them to display certain characters, glyphs etc. Also if you remove the wrong fonts you can kill the system.
It puts them at the bottom of the fonts list anyway so just ignore them. smile
Re: OS X Font management [Re: Reboot] #637392 02/11/16 03:43 PM
Is this thing on?
Is this thing on?
…so just ignore them.
NEVER! cry grin
Re: OS X Font management [Re: Reboot] #637395 02/11/16 06:10 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
So using Cocktail is going to screw things up?
Page 1 of 3 1 2 3
