No Apache #636027 12/11/15 03:22 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
I bought a copy of Leopard 10.5, and just found out it has NO APACHE or PHP.
What can I do?
I'm trying to set up a "site" on a standard Mac Mini
Re: No Apache [Re: PapaBill] #636031 12/11/15 03:56 PM
Reboot Offline
Re: No Apache [Re: Reboot] #636037 12/11/15 04:34 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
Already been there. There is no apache on the machine, even with a new install of OS X.
I have searched the HD for httpd.conf, and php.ini.default, and nothing shows up.
Re: No Apache [Re: PapaBill] #636038 12/11/15 04:43 PM
Reboot Offline
You do know those are hidden files? When in the Finder go to Go in the menu bar, drag down to Go to Folder. Type in /private/etc/ and hit Return, the apache2 folder is in there.
Re: No Apache [Re: Reboot] #636042 12/11/15 08:48 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
Great, thanks. Now, I gotta find MySQL for this OS X (10.5.8), and I'll be ready to set up a forum site. I have searched all over, but cannot find old versions. Seems that stuff for the OLDER versions of OS X are "thrown away"
Re: No Apache [Re: PapaBill] #636058 12/12/15 01:57 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
Found it!!
