Audio Caller ID #635649 11/20/15 08:00 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
On my windoze machine, I have an audio caller ID program that announces to me who is calling, then records it to a log.
Is there such a program that will run on this machine (Mac Mini-1.43 Ghz Power PC G4)? I'm running Mac OS X 10.5.8 with a 74.5Gb HD.
Thanks
Re: Audio Caller ID [Re: PapaBill] #635664 11/21/15 01:47 AM
Reboot Offline
Does the windoze machine connect to a cell phone or a land line to get the number?
Re: Audio Caller ID [Re: PapaBill] #635678 11/21/15 02:13 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
Yes, it is connected to a land line via modem.
Re: Audio Caller ID [Re: PapaBill] #635690 11/21/15 06:16 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
I'm working on a DIFFERENT (identical) Mac Mini on this one. The OTHER Mac Mini is doing nothing but showing a blue screen.
Re: Audio Caller ID [Re: PapaBill] #635691 11/21/15 06:32 PM
Reboot Offline
Out of luck then, the mini doesn't have a modem, and off the top of head I really can't give any recommendation for an external USB modem that would work.
Re: Audio Caller ID [Re: Reboot] #635692 11/21/15 06:34 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
Yes, this mini DOES have a modem as well as Airport and EtherNet hookup
Re: Audio Caller ID [Re: PapaBill] #635695 11/21/15 06:58 PM
Reboot Offline
Okay, I'll look into the caller ID software.
I'll get back with you probably tomorrow, heading out for the rest of the day.
