El Capitan boots into Recovery Mode #635619 11/19/15 07:32 PM
Acumowchek Offline OP
Is this thing on?
Is this thing on?
I can't figure it out. A cold startup or restart, and my iMac boots into Recovery Mode.
I have to hold down the Option key to select the El Capitan HD.
I've selected it as the startup disk, used Disk First Aid, but nothing is helping.
I don't reboot that often, but it is still an annoyance.
I don't want to re-install from Time Machine, and I've never had to install from recovery mode. I'm baffled.
Re: El Capitan boots into Recovery Mode [Re: Acumowchek] #635623 11/19/15 09:08 PM
Reboot Offline
Zap the PRAM for starters.
Did you repair the disk from the recovery partition?
Re: El Capitan boots into Recovery Mode [Re: Acumowchek] #635624 11/19/15 09:31 PM
Reboot Offline
Is this the new iMac?
Re: El Capitan boots into Recovery Mode [Re: Reboot] #635625 11/19/15 10:13 PM
Is this thing on?
Is this thing on?
No, this is my 2011 home iMac.
No, I did not use First Aid from Recovery. (They took away Repair Disk, didn't they?)
No, I did not zap the PRAM.
Will give it a go tonight. Thanks (as always!).
grin
Re: El Capitan boots into Recovery Mode [Re: Reboot] #635646 11/20/15 06:48 PM
Is this thing on?
Is this thing on?
PRAM (NVRAM?) did the trick!
You are genius, I tells ya, GENIUS! cool
Just wondering why it started doing that.
Re: El Capitan boots into Recovery Mode [Re: Reboot] #635650 11/20/15 08:18 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
OK.. and what cause a system to NOT boot into recovery mode. My SSD sys on my MP at home won't boot recovery.
Re: El Capitan boots into Recovery Mode [Re: Acumowchek] #635656 11/20/15 10:10 PM
Reboot Offline
Why? Don't know, don't care. Stuff like that's why I have a job. grin
Re: El Capitan boots into Recovery Mode [Re: NucleusG4] #635657 11/20/15 10:12 PM
Reboot Offline
Does the recovery partition show up if you hold the option key down at start up? You installed from that USB stick right?
Re: El Capitan boots into Recovery Mode [Re: Reboot] #635660 11/20/15 11:24 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Will check.
