Time Machine Backup Failure #635474 11/12/15 02:04 AM
Acumowchek Offline OP
Is this thing on?
Is this thing on?
Well, after 4 years, my 2TB Time Machine backup HD is full, and I keep getting an error message "Backup Failed - Time Machine couldn't back up to Backup".
I thought it was supposed to automatically delete redundant backups to make room for more. Not happening.
I have my data manually backed up on other media, so should I just wipe this HD clean and start from scratch?
Re: Time Machine Backup Failure [Re: Acumowchek] #635475 11/12/15 02:53 AM
Reboot Offline
If you don't think you'll ever have to go back to retrieve an older item yes.
You may be able to free up space on TM by entering Time Machine from the TM Menu and deleting all backups of big files. For me it's Parallels virtual machine for one. When ever I launch Parallels it changes the Windows VM so TM copies the whole thing again, 30 G.
If you use Toast you may have a lot of Roxio Converted Items folder backed up, it just holds temp files.
Re: Time Machine Backup Failure [Re: Reboot] #635478 11/12/15 03:22 AM
Is this thing on?
Is this thing on?
Thanks. I've double checked that all the files I need are safe.
It will be easier to wipe clean, than to try and delete specific backups.
But I'll wait a few days to make sure. wink
Re: Time Machine Backup Failure [Re: Reboot] #635620 11/19/15 07:34 PM
Is this thing on?
Is this thing on?
Erased the HD and everything is fine. Thanks!
