Airport Time Capsule &SSD's with Hub #635417 11/08/15 08:36 PM
B
billwhit1 Offline OP
B
Airport time capsule 2TB (router and usb for additional Hard diskís) Airport time Capsule
I have an iMac and a 2TB Airport time Capsule, WiFi, a laptop and several Apple Devices. I am utilizing a good portion of my Time Capsule to the Time machine Backups. My iMac also has a 1TB internal hard disk. I also have three other external hard disks. A 1TB SSD, .5 TB SSD and a 2Tb Seagate (relegated to the MS side of my setup). What I want to do is be able to see my 2 SSDís and address them directly. I have tried to use an alias, assign an Icon and use them just as I would use my internal HD and my Airport Time capsule. I just canít seen to get it organized. I have a 5 port powered USB hub. Not only having a problems with the alias but volumes donít like easy icons. I need advice on how to set up the 2 ssdís and give then an icon that I can see in finder under devices. I would appreciate any advise you may offer.
billwhit1
Re: Airport Time Capsule &SSD's with Hub [Re: billwhit1] #635418 11/08/15 08:44 PM
Reboot Offline
Is MS a Windows machine or Virtual Machine in Parallels.
What OS is on each machine?
