Windows 10 issue #633836 09/12/15 08:24 PM
MacBozo Offline OP
I (my wife) decided that my granddaughter should have a computer at her house that she couple use for her homework, etc. We got her a Windows 10 laptop.
Question: How do you get it to establish an internet connection over a wi-fi network? It connects just fine to my wi-fi network, but refuses to enable an internet connection.
Re: Windows 10 issue [Re: MacBozo] #633837 09/12/15 09:05 PM
Reboot Online Content
Online Content
Reboot?
Router and computer.
I've had to go in and tell it to forget the network then re-establish sometimes.
Re: Windows 10 issue [Re: Reboot] #633872 09/14/15 01:18 AM
MacBozo Offline OP
Thanks. I'll try that the he next time it is here. Why does Windows make it such a PITA?
Re: Windows 10 issue [Re: MacBozo] #633903 09/14/15 07:12 PM
MacBozo Offline OP
Also, when I did the initial setup, there was no problem with the internet connection on my wifi network.
Edit: I just tried using my iPhone's personal hotspot. It connected to the "wifi" network, but still no internet connection. They no longer have internet access at their house (where I am a at the moment). I'm just flummoxed that it was OK during the initial setup and successfully downloaded Office and McAfee AV. Could the McAfee suite be blocking it? I can't find a setting there.
Bizarro! [Re: MacBozo] #634221 09/22/15 04:14 PM
MacBozo Offline OP
Got the laptop here, finally, to troubleshoot. Booted it up and it connected to my wifi network with an internet connection.
#headscratcher
Re: Bizarro! [Re: MacBozo] #634233 09/22/15 05:06 PM
Online Content
Okay I could blame this on Windows but I've seen it on Mac laptops too. Sometimes rebooting the router helps. Something about going from one network to another confuses them. On Windows I go in and tell it to forget the network, on Macs delete the Wifi from Network prefs and re-add it.
Happens with phones too. The other day my sister called, (love being family tech support) they were on vacation and trying to connect to the wireless network. One iPhone wouldn't, so I had her reboot the router, all was well. Rebooting the phone didn't do it.
Re: Bizarro! [Re: Reboot] #634237 09/22/15 05:26 PM
MacBozo Offline OP
It may have gotten confused when it associated with their home wifi which no longer has internet access. I set it to forget that network the last time I was at their house.
Yes, I've had to reboot the dLink extender more often than I like.
