Airport card for PowerMac G5 #632872 08/13/15 01:49 AM
C
choker Offline OP
Where's the RAM?
Where's the RAM?
C
Where can I find an Airport(Wifi?)card for my PowerMac G5 M9591LL/A
It was optional when I purchased the Mac and I didn't opt. Now I need it to connect due to physical restraints on using Cat5.
I've seen several cards for the G5 but none I can be sure is the correct one. I've also seen reference to an antenna?????
Any help greatly appreciated
Re: Airport card for PowerMac G5 [Re: choker] #632877 08/13/15 03:47 AM
Reboot Online Content
Online Content
That's a toughie. It can be an expensive kit.
Your best bet is to get one of these and put it into Wireless Client mode. It will pick up the wireless then you take an ethernet cable from the TP-Link to the G5.
Microcenter has it for less than $20 here.
Re: Airport card for PowerMac G5 [Re: choker] #632921 08/14/15 02:08 AM
C
choker Offline OP
Where's the RAM?
Where's the RAM?
C
Thanks.
That sounds like just what the Dr. ordered
choker
Re: Airport card for PowerMac G5 [Re: Reboot] #633160 08/21/15 01:56 AM
C
choker Offline OP
Where's the RAM?
Where's the RAM?
C
Went with your recommendation.
Just set it up, logged in from the G5 to send this.
As usual Reboot strikes again
Many thanks
choker
Re: Airport card for PowerMac G5 [Re: choker] #633161 08/21/15 02:07 AM
Online Content
I love it when a plan comes together. cool
