Is there a workable SCSI ti USB or Firewire conver #632683 08/08/15 02:46 AM
C
choker Offline OP
Where's the RAM?
Where's the RAM?
C
I have a perfectly functional UMAX Powerlook scanner (SCSI) that I can't use with my G5 or with my Mac Mini. Hate to get rid of a good unit if there are workable options.
Any workable suggestions?
choker
Re: Is there a workable SCSI ti USB or Firewire conver [Re: choker] #632689 08/08/15 11:18 AM
Reboot Offline
It's time to bury the Umax. You can get a Canon LIDE 220 or 120 for less than you pay for a SCSI to USB adapter. It does require 10.6.8 or greater though. You didn't mention what version of the operating system you're running.
Besides costing less the new scanners have a much smaller footprint, and most of them don't require a power supply. It runs off the USB cable.
Re: Is there a workable SCSI ti USB or Firewire conver [Re: choker] #632691 08/08/15 11:24 AM
NucleusG4 Offline
Master•Blaster
Master•Blaster
There are solutions out there... but the cost is close enough to just warrant buying anew scanner IMO.
