Keyboard,video,mouse for 2 Macs #631681 07/06/15 08:56 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
Is there such a thing as a KVM switch (Keyboard, video, mouse) to use one keyboard, video and mouse for two Macs?
Thanks
Re: Keyboard,video,mouse for 2 Macs [Re: PapaBill] #631683 07/06/15 09:08 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Like this...
(made for Mac minis stacking)
http://www.newegg.com/Product/Product.as...mp;gclsrc=aw.ds
Re: Keyboard,video,mouse for 2 Macs [Re: PapaBill] #631688 07/07/15 01:58 AM
Reboot Offline
That IOGEAR is a clean mini setup, nice.
If you only need it for 2 computers, and I know you like to spend as little as possible. smile
Used from ebay, two port.
Re: Keyboard,video,mouse for 2 Macs [Re: PapaBill] #631727 07/08/15 02:28 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
I found a USB KVM that works for both Macs, but I cannot figure out how to get from one Mac to the other.
On a KVM for a PC, hitting the ScrLk twice then the down arrow changes from one PC to the other. But on the Mac keyboard, there is no ScrLk. Does anyone have experience with this problem?
I'm using the KVM with two Mini-Mac A1103 machines, one running OS X 10.4.11 and the other running OS X 10.5.8.
Thanks.
Re: Keyboard,video,mouse for 2 Macs [Re: PapaBill] #631747 07/08/15 04:05 PM
Reboot Offline
If we knew what model of KVM we might be able to help. You need to give us more detailed information in your posts.
Re: Keyboard,video,mouse for 2 Macs [Re: PapaBill] #631776 07/09/15 06:42 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
I'll see if I can figure it out. It's in pretty bad shape (very dirty) and the label is VERY messed up,
Re: Keyboard,video,mouse for 2 Macs [Re: PapaBill] #631777 07/09/15 07:03 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
OK.. if it's USB and you have it hooked up to one Mac you can go into System Profiler... click "USB" on the right and see it listed in the devices. Should be able to glean some info that way.
Re: Keyboard,video,mouse for 2 Macs [Re: PapaBill] #631783 07/09/15 08:05 PM
PapaBill Offline OP
Where's the cache?
Where's the cache?
Found it. Accidentally. There is a "loose" clear bar on the front of the main part, and when you click one side of it, it changes computers. Click the other side, and you get the OTHER computer. DOH!!
