Is there a padding team here too?<br>If so, I'm ready to join up.<br>(lowly #22)<br><P ID="edit"><FONT SIZE=-1><EM>Edited by sross on 05/06/03 11:56 AM (server time).</EM></FONT></P>
#63032 - 05/06/0309:04 AMRe: Im #9 on MM at padding@work/home
[Re: Biggerfoot]
greenme1
Loc: Pittsburgh, PA
Yeah, swatcat made an appearance in Lori's B-Day thread, and Marg hasn't been here for a while...<br><br>"If everything seems to be going well, you have obviously overlooked something. "
#63034 - 05/06/0309:18 AMRe: Im #9 on MM at padding@work/home
[Re: JonnyCat]
sean
Loc: my basement
wow...i consider myself a regular who posts pretty often and macgizmo posts 5 or more messages to every one i post. wow! and, i started at least a year ahead of him. <br><br>[color:blue] -sean</font color=blue>
Loc: New Hampshire
html markup<br><br>< strike > text you want to strike out < /strike ><br><br><br>remove the space after the <<br>remove the space before the ><br><br>so you can <strike>strike out anywords you like</strike><br><br>
