iCloud keychain not working? #629689 05/08/15 07:32 PM
J
John Rougeux Offline OP
I invented modding!
I invented modding!
J
So, got something off of eBay. First time in awhile so when I went to pay using Paypal, I forgot my password. Requested one, used the Safari recommended one that saves to iCloud Keychain. Went back to eBay to pay for the item, and it doesn't autofill the password, instead suggesting a different password (Safari suggested password).
How do I tell Safari that it already used a password and to fill it in?!
Edit: I found a way to do it, by going through Safari Preferences and Passwords...but come on! Isn't that what I should have to avoid?
Re: iCloud keychain not working? [Re: John Rougeux] #629695 05/09/15 03:53 PM
Reboot Offline
You might want to try the following from this link.
If you can't sync iCloud Keychain with other devices.
Make sure that your device is on a Wi-Fi or cellular network. If the connection appears strong, try these steps:
Turn off iCloud Keychain on all devices.
Turn on iCloud Keychain on the device that has the most up-to-date keychain items.
Turn on iCloud Keychain on your other devices. They will be updated with your new iCloud Keychain.
