iMac G5 LCD repair #629315 04/16/15 07:02 PM
T
TCPMeta Offline OP
MacModder
MacModder
T
Haven't been in the Mac world in a great while.
Yesterday I bought a iMac G5 for ten bucks at a thrift store. the LCD panel is busted ad I thought I would tackle the repair. Instead of buying a direct drop in replacement I decided to go the route of the Hackintosh guys but reverse. Toss in a TMDS compatible LCD panel and wire up a DVI connector to the old LCD panel's cable. This way I can connect any 17.1 inch DVI compatible monitor in the system. Or if I really wanted to I could build a custom case for the system. I do have a 32inch LCD TV, just use a DVI/HDMI adapter and get some acrylic sheets.... Nah, after all it's a G5 CPU and I would only run Linux on it.
To live is to let die
Re: iMac G5 LCD repair [Re: TCPMeta] #629318 04/16/15 07:38 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Wow! 4.5 years since last post!
Good to see you again.
Good luck with the mod.
Re: iMac G5 LCD repair [Re: TCPMeta] #629328 04/17/15 05:10 AM
T
TCPMeta Offline OP
MacModder
MacModder
T
Yea since the MacMod merge and the hackintosh scene it's been kinda slow on the modding front.
Re: iMac G5 LCD repair [Re: TCPMeta] #629397 04/22/15 08:51 PM
T
TCPMeta Offline OP
MacModder
MacModder
T
Well, sad to say the motherboard is also dead. looks like a power regulator or transistor was broken off when I took it apart. So I stripped it down and planning to use the case for a project and currently rewiring the Bluetooth module to use a standard USB port.
Re: iMac G5 LCD repair [Re: TCPMeta] #629398 04/22/15 09:33 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Never say die! laugh
Re: iMac G5 LCD repair [Re: TCPMeta] #629413 04/24/15 07:07 AM
T
TCPMeta Offline OP
MacModder
MacModder
T
Exactly, it will find life as a Intel based mac.
