Page 1 of 2 1 2
OK, riddle me this #628330 03/10/15 10:46 PM
MacBozo Offline OP
Recently, my cable internet access has been upgraded to 15 mbps download speed. My Mac connected to the router via ethernet gets 17 mbps. My iPhone gets close to 15 mbps when connected via wi-fi to the router's network and to the dLink access point/extender. My wife's Mac when connected to the router via wi-fi gets around 12 -13 mbps and is only getting around 7 - 8 mbps via the dLink. The signal is best from the dLink, though. What gives?
Re: OK, riddle me this [Re: MacBozo] #628337 03/11/15 12:34 AM
Reboot Offline
Is the b wifi on in the router and/or the dlink? That would limit it to 10M max, if that's the way she happens to be connecting. If there is choice of b in either turn it off.
Are the routers dual band, 2.4 and 5 Ghz?
This isn't another case of smoke and mirrors is it? grin
Re: OK, riddle me this [Re: Reboot] #628345 03/11/15 12:58 PM
MacBozo Offline OP
Not sure about b. Pretty sure it's off on the ASUS. I'll have to check the dLink when I get the time. Just thought it odd that my iPhone gets near optimal speed, but her Mac doesn't.
Re: OK, riddle me this [Re: MacBozo] #628350 03/11/15 03:07 PM
Reboot Offline
2.4 Ghz goes through solid objects better than 5 Ghz. b is limited to 10M. g goes to 54 M.
One guess is that even though the dlink is the best signal if it's only getting 7-8 M it may be 2.4 Ghz or 5 Ghz b instead of g. Or it's closer is why the better signal, at either 2.4 or 5.
Your Asus is a weaker signal for her, but is faster you say. Could be weaker because it's 5 Ghz instead of 2.4, or it could be just farther away, and it's connecting at g instead of b.
Re: OK, riddle me this [Re: Reboot] #628362 03/11/15 09:03 PM
MacBozo Offline OP
Both show as connecting as g. The dLink shows 54mbps, consistently. The ASUS is dual band and the 2.4GHz is the SSID we use since the connection via 5GHz is a only. I turned off b/g protection on the ASUS and couldn't find an option for b, g, or n on the dLink, however I believe it's g and n only.
I may have to reboot the dLink because, even though there are clients connected, it doesn't show them (nor does the ASUS).
Re: OK, riddle me this [Re: MacBozo] #628363 03/11/15 09:38 PM
MacBozo Offline OP
Just checked the iPhone via all wi-fi networks:
1. dLink about 20ft away = 13.54 mbps
2. ASUS 2.4 GHz 2 ft away = 15.69 mbps
3. ASUS 5 GHz 2 ft away = 15.64 mbps
4. dLink about 5 ft away = 15.48 mbps
After I rebooted the dLink, connected clients now are listed.
Re: OK, riddle me this [Re: MacBozo] #628376 03/12/15 03:35 AM
Reboot Offline
Nothing like a reboot to clear things up.
Sorry, that never gets old. smirk
Re: OK, riddle me this [Re: Reboot] #628403 03/12/15 07:54 PM
MacBozo Offline OP
I still haven't had the time to check my wife's Mac, though. That was where the problem is.
Re: OK, riddle me this [Re: MacBozo] #628479 03/14/15 03:21 PM
MacBozo Offline OP
Checked the wife's this morning.
Via the ASUS 25 - 30 feet away: 12.5 mbps
Via the dLink 15 feet away: 11.5 mbps
That's within reason, I guess. I'm still thinking the problems are primarily with her MacMini.
Re: OK, riddle me this [Re: Reboot] #631533 07/03/15 01:16 AM
ichi Offline
i'm going outside the graphics are amazing
never did, never will.
hello, old man!
Page 1 of 2 1 2
