F11 key not working in Win8.1 under Parallels #626685 01/19/15 12:32 AM
J
John Rougeux Offline OP
I invented modding!
I invented modding!
J
Any alternative to this key?
Re: F11 key not working in Win8.1 under Parallels [Re: John Rougeux] #626686 01/19/15 01:15 AM
Reboot Online Content
Online Content
Re: F11 key not working in Win8.1 under Parallels [Re: John Rougeux] #626687 01/19/15 01:23 AM
Online Content
What are you using it for BTW? What should happen, and what does happen.
F11 by default is for Desktop. Go to System Preferences, Mission Control, and turn of anything that is on for F11.
Re: F11 key not working in Win8.1 under Parallels [Re: John Rougeux] #626695 01/19/15 02:47 AM
J
I invented modding!
I invented modding!
J
Working in Excel.
The task is to:
drag over the range A3:D8 to select it. Press F11. The chart immediately appears on a new chart sheet named Chart1. Contextual tabs for working with the chart also appear.
The reason I got Windows and Parallels was because some Windows commands in Excel are different than the Mac version.
Re: F11 key not working in Win8.1 under Parallels [Re: Reboot] #626696 01/19/15 02:53 AM
J
I invented modding!
I invented modding!
J
Originally Posted By: Jim_
Thanks! This worked:
Using OS X Preferences:
a. Open System Preferences ► Keyboard ► Keyboard Shortcuts
b. Change shortcuts so that F8-F12 are left unused by OS X
I deselected F11 and F12
