Page 1 of 4 1 2 3 4
Voice memos #626633 01/17/15 01:09 AM
P
Papa Offline OP
In Vegas with Nina Agdal
P
I have some voice memos on my phone that I want to put in iTunes but can't get them to transfer. I have them checked under music in the phone preferences but they will not transfer. I saw a program called iPhone Manager that will do it but was wondering why the transfer would not work and if there was something I was missing.
Common sense and deodorant are a lot alike. People who need it the most don't use it.
Re: Voice memos [Re: Papa] #626636 01/17/15 02:47 AM
Reboot Offline
So you have 'Sync voice memos' checked in iTunes, is that what you mean? It should put them into your Songs and reference them in a Voice Memos Playlist.
Re: Voice memos [Re: Reboot] #626638 01/17/15 03:18 AM
P
Papa Offline OP
P
Sync voice memos is checked in iTunes. They do not show up in songs and are not referenced in the Voice Memos Playlist.
Re: Voice memos [Re: Papa] #626641 01/17/15 04:30 AM
Reboot Offline
Try unchecking then sync, then check it again and sync.
BTW iExplorer works well to transfer. The demo can transfer something like 10 tracks at a time.
Re: Voice memos [Re: Reboot] #626650 01/17/15 03:56 PM
MacBozo Offline
If that fails, just email them to yourself and, then transfer them to iTunes.
Re: Voice memos [Re: MacBozo] #626662 01/18/15 01:48 AM
Reboot Offline
Good idea, but what do you know OFI. grin
Were we that young at one time? wink
Re: Voice memos [Re: Reboot] #626663 01/18/15 02:52 AM
P
Papa Offline OP
P
I tried your last suggestion of unchecking then syncing and checking and syncing and that didn't work. I downloaded the trial version of iExplorer and it recognized everything on the phone except for music. I have a couple of voce memos that are too large to email and I need to burn them to a disc. I am on Mavericks so I can't use Air Drop.
Re: Voice memos [Re: Papa] #626664 01/18/15 03:46 AM
Reboot Offline
Does your iExplorer look like this except sans Rick James when your phone is plugged in?
Re: Voice memos [Re: Reboot] #626665 01/18/15 03:57 AM
P
Papa Offline OP
P
There is nothing there when expanded. It is blank.
Re: Voice memos [Re: Papa] #626670 01/18/15 01:21 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Try this ...
Go to your iTunes media and move all voice memos to an alternate location.
1) I backed up and sync your phone
2) deleted the voice memos playlist in iTunes
3) deselected "include voice memos" under the Music tab
4) clicked "Apply"
5) when sync was done, shut down iTunes
6) disconnected and reconnected iPhone and restarted iTunes
7) reselected "include voice memos" under the Music tab
8) clicked "Apply"
A new Voice Memo playlist will be created with your voice memos in iTunes.
Hopefully the sync will place the new files in the folder.
Now move the previous memos back into the folder.
Page 1 of 4 1 2 3 4
