Build a "Hackintosh" computer #625678 12/10/14 04:39 PM
P
pcarlbe Offline OP
P
Read this on Flipboard and found it interesting, as I, myself, have an older Mac Mini that I'd like to update. My apologies if this has already been covered.
http://www.cultofmac.com/302922/how-to-build-gaming-hackintosh-part-1-hardware/
http://www.cultofmac.com/305204/buil-gaming-hackintosh-part-two-2-software/
Parent link: http://www.cultofmac.com/category/how-to/
Thanks
Re: Build a "Hackintosh" computer [Re: pcarlbe] #625789 12/14/14 07:08 PM
J
John Rougeux Offline
I invented modding!
I invented modding!
J
Sounds very cool and interesting. Have thought about this myself, but always chickened out. If you notice on the software install page:
http://www.cultofmac.com/304167/how-to-build-gaming-hackintosh-part-3-software/
Down near the bottom are some tips that make me leery:
After restarting your Hackintosh with your fingers firmly crossed, your components should be working.
and this one:
If, after following all the steps above, you have a working Hackintosh with no issues whatsoever, you’re incredibly lucky.
Read more at http://www.cultofmac.com/304167/how-to-build-gaming-hackintosh-part-3-software/#QsFe0AHtLYvdiIcp.99
Maybe one day I'll give it a try. But I use Newegg...the parts are cheaper there.
