Heads up! #625241 11/28/14 12:32 AM
MacBozo Offline OP
The D-Link DAP-1320 wi-fi extender is on sale for $24.99 on the D-Link web site and at participating retailers for Black Friday. I think I'm going to have to get one at Office Depot tomorrow afternoon after I get off work.
Re: Heads up! [Re: MacBozo] #625277 11/28/14 11:23 PM
MacBozo Offline OP
Got it. Set it up. Works as advertised. Hopefully, this will allow the signal to bypass the interruption of signal when my father-in-law is in residence (keep my wife from complaining). grin
Re: Heads up! [Re: MacBozo] #625280 11/29/14 03:24 AM
Reboot Offline
Worth every penny. smirk
It interfaced with the ASUS easily?
Re: Heads up! [Re: Reboot] #625327 11/30/14 11:04 PM
MacBozo Offline OP
WPS buttons in the proper sequence worked flawlessly. I did have to hard reboot the ASUS afterwards, so I could log in to it again. grin
Re: Heads up! [Re: MacBozo] #625334 12/01/14 01:31 AM
Reboot Offline
IOW RTFM? grin They have a WPS button, great. Thx.
Have not set one of those up yet. For even the regular price a nice compact solution.
Cable company gouging #625699 12/11/14 12:30 AM
MacBozo Offline OP
My local cable TV/internet provider has a new service they've named "Echo." It's whole house wi-fi. They will, for $29.95, come out and install access points in order to eliminate wi-fi dead zones. Of course, that will also cost you an extra $10/month plus $3/month for each AP installed. Their APs are directly wired to the cable, however. If you should need additional APs installed or a service call to correct a problem, that's another $29.95 charge.
I solved my household's wi-fi weaknesses with a one time $24.99 purchase of a Dlink DAP-1320 wi-fi range extender (essentially a wi-fi AP). It was a Black Friday special which normally retails for $40 or $50 depending on where you shop. Set up was effortless and took mere minutes.
This really isn't rocket science, folks.
Re: Cable company gouging [Re: MacBozo] #625791 12/14/14 08:59 PM
bird Offline
I invented modding!
I invented modding!
I't is if you don't speak wi-fi laugh
however I can read happy..
way to go Kiddo
you did good smile
