Bringing a keyboard back to life? #625069 11/23/14 05:12 PM
J
John Rougeux Offline OP
Member # -1
Member # -1
J
When it rains, it pours.
Decided to clean my keyboard for my iMac. It's one of those silver/flat/metal ones that is USB powered. Love it.
So i got a piece of paper towel slightly damp and proceeded to clean it. Now it no longer works. I have a backup, older white one, but was hoping to get this keyboard back.
It's been 2 days, so it's dried out...not that I soaked it.
Re: Bringing a keyboard back to life? [Re: John Rougeux] #625070 11/23/14 05:47 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
What is it doing? Nothing? Won't power up?
Re: Bringing a keyboard back to life? [Re: NucleusG4] #625071 11/23/14 05:49 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Possibly it is still damp? The tolerances around those keys are pretty tight... might still be holding moisture. Run a blow dryer across it maybe?
Re: Bringing a keyboard back to life? [Re: John Rougeux] #625077 11/23/14 06:10 PM
J
Member # -1
Member # -1
J
completely dead.
I'll try a blowdryer next.
Re: Bringing a keyboard back to life? [Re: John Rougeux] #625084 11/23/14 10:35 PM
Reboot Offline
Should be dry by now. If it was unplugged getting wet wouldn't have hurt it.
Maybe a key is stuck? Have you tried running your palm over all of the keys?
Re: Bringing a keyboard back to life? [Re: John Rougeux] #625085 11/24/14 12:04 AM
J
Member # -1
Member # -1
J
what if it was plugged in?
I have run fingers, palms and knuckles over all the keys
Re: Bringing a keyboard back to life? [Re: John Rougeux] #625087 11/24/14 12:15 AM
NucleusG4 Offline
Master•Blaster
Master•Blaster
If it was plugged in it could have shorted something out.
Re: Bringing a keyboard back to life? [Re: NucleusG4] #625091 11/24/14 12:29 AM
J
Member # -1
Member # -1
J
Yeah, I'm thinking that is what happened.
