Outlook 2010 & iCloud #624890 11/18/14 10:50 PM
Acumowchek Offline OP
Is this thing on?
Is this thing on?
Does anyone use iCloud on Windows?
All I really want to do is set up an iCloud email account in Outlook 2010.
Eazy Peezy, right?
Edit: Should I download the icloud control panel for Windows, or jus skip it?
Re: Outlook 2010 & iCloud [Re: Acumowchek] #624897 11/19/14 02:03 AM
Reboot Online Content
Online Content
If you want to use the iCloud Control Panel you can, and be bugged by Apple Updates, or use the settings here:
http://support.apple.com/en-us/HT202304
Re: Outlook 2010 & iCloud [Re: Reboot] #624902 11/19/14 10:18 AM
Is this thing on?
Is this thing on?
No control panel it is then. Thanks!
