WiFi Scan Utility #623656 10/14/14 04:54 PM
Acumowchek Offline OP
Is this thing on?
Is this thing on?
Found something new, thought I would share.
Detecting WiFi Channels in Mac for best performance.
Mac OS X comes with a useful tool that allows you to find out which channel is least congested and most optimum for your router. However, the tool is hidden and not easily accessible.
1. Press the “Option” button and click the “Wifi” icon at the system tray. In the dropdown, you should see an option “Open Wireless Diagnostic”.
mac-open-wifi-diagnostic
2. In the “Wireless Diagnostic” window, move your cursor to the menu bar and select “Windows -> Utilities”. Go to the “Wifi Scan” tab and click “Scan Now”.
mac-wifi-scan-best-channel
3. Once it has finished scanning, you will be able to see which are the best channels for your router and WiFi network.
Re: WiFi Scan Utility [Re: Acumowchek] #623658 10/14/14 05:05 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Jeez dude.. whynchya run all over the internet wit dis? cool
Re: WiFi Scan Utility [Re: NucleusG4] #623659 10/14/14 05:08 PM
Is this thing on?
Is this thing on?
Stalker… grin
Re: WiFi Scan Utility [Re: Acumowchek] #623661 10/14/14 05:31 PM
Reboot Online Content
Online Content
Well how about that horned one, got one on me. Thx cool
Re: WiFi Scan Utility [Re: Reboot] #623666 10/14/14 06:13 PM
Is this thing on?
Is this thing on?
Ha! (Marked on my calendar for future reference). laugh
Re: WiFi Scan Utility [Re: Acumowchek] #623669 10/14/14 06:33 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Re: WiFi Scan Utility [Re: Acumowchek] #623675 10/14/14 08:56 PM
Online Content
I guess one out a hundred instances is not bad. smirk
Re: WiFi Scan Utility [Re: Reboot] #623687 10/15/14 12:22 AM
NucleusG4 Offline
Master•Blaster
Master•Blaster
I'll take those odds!
Re: WiFi Scan Utility [Re: Acumowchek] #623731 10/16/14 01:52 AM
MacBozo Offline
If you're still stuck with dust all over you, in Lion you can get similar info at About This Mac>System Report>Wi-Fi. In SL, it's same path except it's "Airport" instead of Wi-Fi.
