iOS8 bug #623096 09/30/14 05:38 PM
NucleusG4 Offline OP
Master•Blaster
Master•Blaster
Nasty iOS 8 Bug Could Erase Your iCloud Drive Documents
According to the report, the option to "Reset All Settings," found under Settings — General — Reset in iOS 8, also deletes documents from the iCloud Drive — permanently.
The option, which normally resets settings to factory defaults, clearly states that "no data or media will be deleted." However, after some users on MacRumors' forum complained about the bug, MacRumors tested the option out, and indeed, all the iWork documents stored in iCloud Drive both on the iPhone and on iCloud.com were gone.
Even worse, after iCloud synced with a Mac running OS X Yosemite, the documents were deleted from the Mac as well. Some of the documents — including Preview and TextEdit files — were untouched, but all iWork files seem to be affected.
In some scenarios it's possible to retrieve these files from a backup folder, or via Time Machine, but nothing is certain at this point, and Apple still hasn't publicly acknowledged the bug. For now, iOS 8 users who have iCloud Drive enabled should probably avoid using the "Reset All Settings" option.
http://mashable.com/2014/09/30/ios-8-bug-erase-icloud-drive-documents/
Re: iOS8 bug [Re: NucleusG4] #623098 09/30/14 07:03 PM
P
Papa Offline
In Vegas with Nina Agdal
P
I took Macworld's advice and didn't turn on iCloud Drive.
http://www.macworld.com/article/2684105/...e-just-yet.html
Common sense and deodorant are a lot alike. People who need it the most don't use it.
Re: iOS8 bug [Re: Papa] #623099 09/30/14 07:10 PM
Acumowchek Offline
Is this thing on?
Is this thing on?
Me neither.
I understand the occasional bug, but Apple had better step it up a bit.
Re: iOS8 bug [Re: NucleusG4] #623157 10/02/14 04:37 PM
MacGizmo Offline
What?
What?
Now the update that supposedly fixes the last update causes some to lose Bluetooth connectivity with car stereos and headphones.
Yeah. A little more emphasis on QA by Apple would be appreciated.
The Graphic Mac - Tips, reviews & more on all things OSX & graphic design.
