iOS 8.0.2 #623039 09/28/14 06:33 PM
Reboot Offline OP
Did it Friday. Got rid of the Portrait to Landscape bug in Safari on my 4S. Sometimes I had to toggle Portrait to Landscape to get it to go to Landscape. We'll see if the Messages bug is gone, when making a new message sometimes it said Unknown at the top instead of New Message. In general the phone seemed a wee bit slower with 8.0 but by no means a deal breaker. 8.0.2 brought most of it back. Pull the trigger I say.
Re: iOS 8.0.2 [Re: Reboot] #623043 09/28/14 06:48 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Yep. Doing it on my daughters iPad first. 4+ hours to download... 10 minutes left.
Re: iOS 8.0.2 [Re: NucleusG4] #623045 09/28/14 07:04 PM
Acumowchek Offline
Is this thing on?
Is this thing on?
4+ hours to download ???
My iPod and 5S only took about 25 minutes each.
Re: iOS 8.0.2 [Re: NucleusG4] #623050 09/28/14 09:49 PM
Reboot Offline OP
So much quicker going through iTunes. My 4S took about an hour 15 or so from start of download to back up and running.
Re: iOS 8.0.2 [Re: Reboot] #623051 09/28/14 10:38 PM
Acumowchek Offline
Is this thing on?
Is this thing on?
I don't get it. Why was mine so quick?
I backed up everything before, downloaded through iTunes, and was up and running in ½ an hour.
Re: iOS 8.0.2 [Re: Reboot] #623053 09/28/14 11:02 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
That was thru iTunes.
Installed and looks good.
There has always been a problem with Other.
If you look at the graph of what is on your device... Other presents a problem for a lot of people. Just Goggle iPad Other.
Anywhoo.. I was about to do a Restore as New after this update and manually set everything up on the iPad... but this update fixed it.
Other went from 7.3 GB down to 1.05
On a 32GB device.. that was about 25% of the space.
Re: iOS 8.0.2 [Re: NucleusG4] #623058 09/29/14 12:22 AM
Acumowchek Offline
Is this thing on?
Is this thing on?
"Other" is pissing me off.
Organizing files and apps used to be more of a Windows thing, but I find myself doing a lot more maintenance than I used too.
Re: iOS 8.0.2 [Re: Acumowchek] #623063 09/29/14 02:52 AM
Reboot Offline OP
Do you have a lot of Messages with videos and pics?
Re: iOS 8.0.2 [Re: Reboot] #623064 09/29/14 03:16 AM
Acumowchek Offline
Is this thing on?
Is this thing on?
NOPE!
