Page 1 of 2 1 2
Logged out #619876 07/15/14 05:52 AM
lanovami Offline OP
This space for rent
This space for rent
My iPhone 4S, iOS 7.1.2 has started showing me logged out of this site after a short interval recently. It might have happened since a recent OS upgrade. I don't think I changed any settings. Other sites stay logged in just as before. My iPod, OS6 has no trouble staying logged in here either. Suggests?
We are what we repeatedly do - Aristotle
Re: Logged out [Re: lanovami] #619877 07/15/14 05:53 AM
lanovami Offline OP
This space for rent
This space for rent
By upgrade I mean a small, integral upgrade not a big one.
Re: Logged out [Re: lanovami] #619883 07/15/14 03:31 PM
Reboot Offline
Nothing has changed. I have the same phone same OS, everything okay. You will get logged out after one month, make sure you checkmark the box to remember me each visit the next time you login.
Re: Logged out [Re: lanovami] #619884 07/15/14 03:39 PM
lanovami Offline OP
This space for rent
This space for rent
Yeah I do that but for some reason after some time when I come (hours? minutes?) I'm not logged in. Luckily I have my iPod as well for now so no big issue
Re: Logged out [Re: lanovami] #619885 07/15/14 03:55 PM
Reboot Offline
Go to Settings, General, Usage, Safari, Website Data, delete forums.AppleCentral.com. It's the cookie for here.
Re: Logged out [Re: lanovami] #619886 07/15/14 04:41 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
On m y phone it seems like i get logged out too... but I think it's when i have absolutley no signal at all... then it loses the login.
Re: Logged out [Re: lanovami] #619893 07/15/14 06:09 PM
lanovami Offline OP
This space for rent
This space for rent
Will try next time I'm on my iPhone, which will likely be the train on the way to work.
Re: Logged out [Re: lanovami] #619896 07/15/14 09:56 PM
lanovami Offline OP
This space for rent
This space for rent
Whoa there are a lot of sites in there. I couldn't find AppleCentral so I just deleted them all. We shall see. I am currently using my iphone for this.
Re: Logged out [Re: lanovami] #619897 07/15/14 09:58 PM
lanovami Offline OP
This space for rent
This space for rent
I tried quitting and starting safari and lost it again.
Re: Logged out [Re: lanovami] #619899 07/15/14 10:14 PM
lanovami Offline OP
This space for rent
This space for rent
Mind you I don't normally have to open and close Safari to lost MacTech I just thought I'd try a test to speed it up.
Again, I have my iPod and my computer at home so it is not very inconveniencing, and only appears to be this site so is not causing wider problems.
Page 1 of 2 1 2
