AppleTV movie #615572 04/19/14 03:39 AM
yoyo52 Offline OP
I bought a movie from iTMS on the AppleTV. I expected that it would be available on my computers, but it doesn't show up, and checking that I've downloaded everything that I've bought on iTunes on the computers indicates that I have nothing to download. So am I wrong to expect that the movie will be available on the computers?
MACTECH ubi dolor ibi digitus
Re: AppleTV movie [Re: yoyo52] #615574 04/19/14 03:51 AM
Acumowchek Offline
Is this thing on?
Is this thing on?
Hmm… I've only bought one movie (To Kill A Mockingbird) through iTunes, but it does show up on every device. I'm not sure about purchasing from AppleTV.
Very happy with the quality, by the way.
Re: AppleTV movie [Re: yoyo52] #615587 04/19/14 11:35 AM
NucleusG4 Offline
Master•Blaster
Master•Blaster
My impression is that if you order it from the computer it's on the computer. But if ordered from the ATV... then its only on the ATV. It used to be either way resulted in the file being on your computer.
Re: AppleTV movie [Re: yoyo52] #615596 04/19/14 02:38 PM
six_of_one Offline
Pool Bar
Pool Bar
On your computer:
- Open iTunes
- Go to the iTunes Store home page
- Select "Purchased" in the Quick Links section at the right
- Select the "Movies" tab
Purchased movies that aren't on your computer should have a little cloud icon at their upper right, which when clicked should start downloading your movie =)
For some reason Apple has made this a lot more arcane than it used to be -- seems like "check for available downloads" hasn't really worked in years (or at least so it seems to me) …
Re: AppleTV movie [Re: yoyo52] #615597 04/19/14 02:49 PM
yoyo52 Offline OP
Thanks, six. What a tangled web we weave, eh! But the check for downloads does work with music, at least for me. Very strange.
