iPhone security update #612797 02/23/14 03:05 PM
Reboot Offline OP
Check your settings on your phones. It's a flaw in SSL. If you're on your own home network, a trusted network, or using the cell tower networks, you're not at risk. When using an unknown Wi-Fi network though, there may be a middleman trying to intercept your information.
So for anyone na´ve enough to do their banking at a Starbucks, you might want to do this update.
http://www.engadget.com/2014/02/21/apple-ssl-update/
Re: iPhone security update [Re: Reboot] #612818 02/24/14 12:32 AM
MacBozo Offline
Done did!
Re: iPhone security update [Re: Reboot] #612824 02/24/14 02:47 AM
Acumowchek Offline
Is this thing on?
Is this thing on?
If I read correctly, there are 3 current updates.
iOS 7
iOS 6
Apple TV
We are waiting for update to OS X.
Don't connect WiFi to Starbucks wink
Re: iPhone security update [Re: Reboot] #612841 02/24/14 11:13 AM
steveg Offline
Making a new reply.
Making a new reply.
I did that update last evening, and an hour later I had updates for a dozen apps waiting! Both of my banking accounts, Kroger, Gas Buddy, Office Depot, AT&T, QRReader, Adobe Reader, DropBox, Ookla SpeedTest, and Google Maps! I was surprised that I didn't have to update my toaster oven. crazy
