Page 1 of 2 1 2
Otterbox fail #612118 02/12/14 04:43 PM
J
John Rougeux Offline OP
Member # -1
Member # -1
J
Thought these things were indestructible?? The case is but did not protect the phone. Puppy knocked it out of my son's hand onto laminate, about 4 foot drop.
in the case:
The phone
Re: Otterbox fail [Re: John Rougeux] #612119 02/12/14 05:02 PM
MacBozo Offline
Did it land flat, face down?
Re: Otterbox fail [Re: John Rougeux] #612120 02/12/14 05:11 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
The good news is that it's probably just the glass and Apple will replace for $35.00 while you wait.
Re: Otterbox fail [Re: MacBozo] #612123 02/12/14 05:27 PM
J
Member # -1
Member # -1
J
Michael, I don't know.
NG4, are you sure? Someone told me $150
Re: Otterbox fail [Re: John Rougeux] #612129 02/12/14 07:03 PM
Reboot Offline
It will probably be around $150. The back glass is probably $35 but not the front. The phone needs to be pretty much totally taken apart.
I see it can be done locally here for $70 by a third party.
If you look on youtube you'll see it's quit a project to DIY. DIY will void the warranty too, I don't know if a third party doing it will, probably so though.
I read where if you ask really nice they may sell you AppleCare+ for $99, then use one of two instances of the $49 fix, leaving you with one $49 fix left, and costing $149 total.
Re: Otterbox fail [Re: Reboot] #612131 02/12/14 08:06 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Oh.. yeah.. if this a iP4 and it's the front then they have to take off back glass, pull inards, and then get to the front glass.
Re: Otterbox fail [Re: NucleusG4] #612132 02/12/14 08:12 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Is this phone a 4 or 4s?
Re: Otterbox fail [Re: John Rougeux] #612134 02/12/14 09:12 PM
J
Member # -1
Member # -1
J
4s
Re: Otterbox fail [Re: John Rougeux] #612135 02/12/14 11:30 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
4 and 4s were the only ones that necessitated going thru the back to get to the front. I guess that's why they changed it at the 5.
I guess $150.00 is the right answer then.
Re: Otterbox fail [Re: John Rougeux] #612160 02/13/14 11:36 AM
steveg Offline
Making a new reply.
Making a new reply.
Take it out of the puppy's allowance. shocked
Page 1 of 2 1 2
