• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mac » Hardware » Macbook Pro 2012 Retina Problems starting.
Topic Options
Hop to:
#611396 - 02/01/14 06:02 PM Macbook Pro 2012 Retina Problems starting.
fiNgERz Offline
Hi all this is my first post on your forum and I'm hoping someone can help me or guide me in the right direction.
I have in my hands a 2012 Macbook Pro retina model which is running os x 10.8.2 my problem is that it will not boot via any method it just gets as far as the Apple logo then the little spinning wheel starts and freezes shortly after.
1. On a standard boot it is in a continuous boot loop. Chimes - apple logo - wheel freeze- reboot prior to resetting the NVRAM it would follow that sequence and display a message that it shutdown because it encountered a problem.
2. Safe boot displays progress bar then switches to gear and freezes for ever
3. Restore freezes the same as above.
4. When I boot and am able to select the restore volume same thing and I have also tried booting from a USB stick with 10.8.2 on it. same just freezes at the gear.
5. I've tried a net boot and although it went and allowed me to select my internet connection once then went on to freeze after doing the NVRAM reset now all I get is a flashing world and then a 0/ symbol at the end.
6. About the only things I can do are boot in single user mode and also verbose mode. I have checked the disk in single user mode and it reports no problems.
7. I have also run the built in AHT and it shows no problems
This Mac has 8 gigs of ram onboard and a ssd there are no other 3rd party devices attached.
anybody have any ideas on how to get this thing to run LOL thanks in advance.
Top
#611399 - 02/01/14 07:35 PM Re: Macbook Pro 2012 Retina Problems starting. [Re: fiNgERz]
Reboot Online   content
Loc: Columbus OH
Welcome to the forums. smile
When you boot in verbose mode does it actually boot to the desktop?
Unfortunately the symptoms you describe sounds like it might be bad RAM, unfortunately the RAM is soldered on the logic board. Then again the symptoms also describe a bad processor. If it won't even boot from a USB stick, there is some kind of hardware problem.
Have you tried booting from a USB hard drive?
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#611401 - 02/01/14 07:47 PM Re: Macbook Pro 2012 Retina Problems starting. [Re: fiNgERz]
Loc: Columbus OH
Okay, rereading your post, on your #1 item, would the machine shut itself down? If so it might be a bad hard drive, if the OS finds a problem with the hard drive on boot it can't fix it will just shut itself off.
If you want to really test the hard drive, if you can boot to the recovery partition go to disk utility and do a Security Erase, move the slider one or two clicks past Fastest, it writes one pass or more of zeros to every block on the HD.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#611403 - 02/01/14 09:39 PM Re: Macbook Pro 2012 Retina Problems starting. [Re: Reboot]
fiNgERz Offline
no does not boot to desktop I guess thats not working either then lol
Top
#611404 - 02/01/14 09:40 PM Re: Macbook Pro 2012 Retina Problems starting. [Re: Reboot]
fiNgERz Offline
can't boot the recovery partition either.. I'm wondering if it's a heat issue. seems a little warm..
Top
#611409 - 02/01/14 11:27 PM Re: Macbook Pro 2012 Retina Problems starting. [Re: fiNgERz]
Loc: Columbus OH
For the heat issue try the link below first. Scroll down a bit for instructions on resetting the SMC. If you think it's heat let it cool down afterwards.
http://support.apple.com/kb/ht3964
I asked before, (there's a method to my madness grin) can you boot from an external USB drive.
Or you can put another machine into FW target disk mode, connect the FW cable, hold down option key on the flaky Mac, and boot from that target disk drive?
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#611436 - 02/02/14 01:55 PM Re: Macbook Pro 2012 Retina Problems starting. [Re: Reboot]
fiNgERz Offline
I will try to setup an external drive I am able to see a usb key but unable to boot from that.
Top
#611437 - 02/02/14 02:04 PM Re: Macbook Pro 2012 Retina Problems starting. [Re: fiNgERz]
Loc: Columbus OH
If you have another Mac, Target Disk mode is easy, don't have to mess with installing a full OS on an external drive.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#611441 - 02/02/14 02:39 PM Re: Macbook Pro 2012 Retina Problems starting. [Re: Reboot]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
Ya... FWTD mode is the easiest way. More info here..
http://support.apple.com/kb/HT1661?viewlocale=en_US&locale=en_US
http://davidbearphotography.com/
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.123 seconds in which 0.111 seconds were spent on a total of 13 queries. Zlib compression enabled.
