Macbook Air antenna connector size? #611115 01/28/14 07:30 AM
S
Spectre08 Offline OP
S
Does anybody know the size and type of the antenna connectors on the Airport Extreme card in the current era (Mid-2013, A1465) Macbook Air?
Below is a picture of the card. The leads on the antenna in my Macbook Air were destroyed while replacing the screen and I need to buy and install a new antenna, but my first attempt at ordering an antenna arrived with connectors that looked the same, but were too large.
Does anybody have any technical specification that need to be met for the antenna?
Re: Macbook Air antenna connector size? [Re: Spectre08] #629583 05/02/15 03:01 AM
K
keith mander Offline
K
Ever figure out the answer to this riddle Spectre08?
I'm in the same boat.
Thanks.
Re: Macbook Air antenna connector size? [Re: Spectre08] #629610 05/04/15 10:59 AM
J
John Rougeux Offline
I invented modding!
I invented modding!
J
Assuming that you have the 13" one, then this is the card:
MacBook Air (Mid 2013 to Early 2015) AirPort/Bluetooth Board
https://www.ifixit.com/Store/Parts/MacBo...ard/IF108-044-1
