Dictation App? #610722 01/21/14 04:15 PM
Acumowchek Offline OP
Is this thing on?
Is this thing on?
Any recommendations?
For some reason I thought iOS had it built inů
Re: Dictation App? [Re: Acumowchek] #610726 01/21/14 05:02 PM
Reboot Offline
Re: Dictation App? [Re: Reboot] #610727 01/21/14 05:08 PM
Reboot Offline
Oh wait, you said iOS.
It is built in, click the microphone instead when you go to type text.
Re: Dictation App? [Re: Reboot] #610728 01/21/14 05:15 PM
Is this thing on?
Is this thing on?
Awe-Some!
I knew it had to be here somewhere!
Re: Dictation App? [Re: Reboot] #610797 01/22/14 07:53 PM
MacBozo Offline
iPhone 4S and newer. grin
Re: Dictation App? [Re: Acumowchek] #614001 03/18/14 12:43 PM
MacGizmo Offline
What?
What?
While you can use the dictate button in almost any text entry field, there is also a dedicated Voice Memos app on the iPhone. It works quite well, and syncs the memos with iTunes (if you wish to do that).
The Graphic Mac - Tips, reviews & more on all things OSX & graphic design.
