MacBozo Nut Dood
It was fine one moment, and then when I picked it up to check my calendar, nothing. Black screen and absolutely no response. iTunes doesn't see it and it isn't charging (doesn't get warm). I dropped it last Monday and cracked (not shattered) the screen glass and it has been working normally until this evening. I'm still nearly 6 months away from my upgrade eligibility, so I may be phoneless for that time.
Apple will replace the glass for less than 50. Usually 35.00
Have them do that and while it's open see if a connector came loose, or at least maybe determine what the problem is. If it's too expensive to fix... go to a third party.
#610630 - 01/19/1409:27 PMRe: iPhone 4 dead
[Re: NucleusG4]
MacBozo Nut Dood
Taking it to my local Apple Tech tomorrow after work. I have a lifetime (phone and owner arrangement) there, since it has been repaired there once. It could be the digitizer that they replaced last time.
