Need more icons... #610228 01/13/14 05:31 PM
DLC Offline OP
I invented modding!
I invented modding!
Neil, Jim... why isn't there an icon for a " :-P " face ? I sure could use one in many posts... there is one in the Posting Icons but not in the Post Faces... can you create or add one ??
Thanks for all the "voodoo", that you do, so well ! laugh
Re: Need more icons... [Re: DLC] #610235 01/13/14 05:40 PM
neil Offline
Neil Ticktin
Neil Ticktin
Honestly, don't know why -- and don't know if it can be added.
The next time I have time to search that down, I'll try to remember.
Re: Need more icons... [Re: neil] #610256 01/14/14 02:38 AM
DLC Offline OP
I invented modding!
I invented modding!
Thanks !!
Re: Need more icons... [Re: DLC] #610258 01/14/14 03:16 AM
Reboot Online Content
Online Content
BTW the image address is http://forums.applecentral.com/images/icons/default/tongue.gif
Paste that into the image tags.
Re: Need more icons... [Re: neil] #610259 01/14/14 03:17 AM
Online Content
Neil, would this help?
Manage > Admin Control Panel > Settings > Graemlins
A Graemlin is our special term for emoticons (named after the member who first suggested it 15 years ago). In this section, you can control which standard Graemlins are available for your community, and create your own custom Graemlins. Just click “add Graemlin,” choose a keystroke, and upload your image. Note that while most Graemlins are tiny, this feature does allow you to upload large images that can then be accessed via a short keystroke. If you wish, you could upload your logo as a Graemlin and use the keystroke :logo: to make it easier to insert it into forum content.
Re: Need more icons... [Re: DLC] #610265 01/14/14 04:35 AM
neil Offline
Neil Ticktin
Neil Ticktin
Jim: A bit different -- but enough info to make it so that it only took about 10 min to figure out.
DLC: Done. tongue away... smile
Thanks!
Neil
Re: Need more icons... [Re: neil] #610266 01/14/14 04:56 AM
Online Content
That's why you get the big bucks. tongue smile
Thx.
