Using airport to stream movies #609112 12/24/13 07:01 PM
J
John Rougeux Offline OP
Member # -1
Member # -1
J
What I want to do is hook up my USB hard drive to this and be able to access it via my appletv. But not sure if I can...is iTunes required for appletv to view movies?
Share your hard drive or printer.
AirPort Time Capsule can turn any external USB hard drive into a secure drive you can share across your Wi-Fi network. So all the documents, videos, photos, and other files instantly become available to anyone, Mac and PC users alike. You can even connect a printer and share it wirelessly.
Re: Using airport to stream movies [Re: John Rougeux] #609117 12/24/13 07:25 PM
J
Member # -1
Member # -1
J
Never mind. iTunes is needed.
Re: Using airport to stream movies [Re: John Rougeux] #609120 12/24/13 07:58 PM
Reboot Offline
As you found out, yes, you need to load the movies into iTunes to watch on AppleTV.
Re: Using airport to stream movies [Re: John Rougeux] #609123 12/24/13 08:28 PM
KateSorensen Offline
77 and counting
77 and counting
I've been meaning to ask,
My movies on my hard drive are in the format ov Video_TX, with Audio_TS folder also. How do I need to process them to watch on my Vizio TV using AppleTV?
tia
Re: Using airport to stream movies [Re: KateSorensen] #609126 12/24/13 09:14 PM
Acumowchek Offline
Is this thing on?
Is this thing on?
I recommend Handbrake .
It's kind of a hassle to recode everything, but they do have presets specifically for AppleTV, and it will save Hard Drive space.
Re: Using airport to stream movies [Re: John Rougeux] #609135 12/25/13 01:23 AM
77 and counting
77 and counting
I'll try one and see how it goes. Thanx
Re: Using airport to stream movies [Re: John Rougeux] #609142 12/25/13 04:52 AM
J
Member # -1
Member # -1
J
Yup, handbrake is the way to go.
