Page 1 of 2 1 2
Slow Loading? #608130 12/07/13 04:15 PM
Biggerfoot Offline OP
I invented modding!
I invented modding!
Is anyone experiencing slow or no loading of the site? It took several minutes to upload this page in order to post.
Also, some of the posting icons are missing.
We are having bad weather but other sites are loading okay.
Re: Slow Loading? [Re: Biggerfoot] #608131 12/07/13 04:29 PM
yoyo52 Offline
Things are pretty speedy here.
MACTECH ubi dolor ibi digitus
Re: Slow Loading? [Re: Biggerfoot] #608132 12/07/13 04:30 PM
Reboot Offline
No problems here. Try clearing your Safari cache, but more than likely it's just a hiccup in your route to the server. If you have a phone to try it on try it using your phone data, not your home wireless. If it's okay on the phone then it's something with your internet connection.
Re: Slow Loading? [Re: Biggerfoot] #608138 12/07/13 05:25 PM
I invented modding!
I invented modding!
Seems to work okay on my phone connection. The second or third time on network connection, it was speedy and then would hang again. I will see if it clears up as it is better as it would not even load yesterday.
The icons are loading now.
Re: Slow Loading? [Re: Biggerfoot] #608142 12/07/13 06:09 PM
neil Offline
Neil Ticktin
Neil Ticktin
If you see slow loading, and you are able to run a traceroute between you and the server, that would be good. Typically, when the reports are not widespread they are often an Internet connectivity issue … not necessarily on your end, but in between where the server is and you.
Re: Slow Loading? [Re: Biggerfoot] #608143 12/07/13 06:10 PM
neil Offline
Neil Ticktin
Neil Ticktin
Also, all the posting icons are there -- so this is a symptom of the slow loading as well.
Thanks!
Neil
Re: Slow Loading? [Re: Biggerfoot] #608144 12/07/13 06:17 PM
I invented modding!
I invented modding!
Took me a few minutes to find the Network Utility in 10.9!
traceroute: Warning: http://forums.applecentral.com/ has multiple addresses; using xxxx
traceroute to http://forums.applecentral.com/ (xxxxx), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 2.025 ms 0.408 ms 1.225 ms
2 cpe-xxxxx-1.cinci.res.rr.com (xxxxxx) 11.478 ms 9.829 ms 11.957 ms
3 be21-1081.blasohdp01r.midwest.rr.com (65.25.146.77) 15.764 ms 12.772 ms 16.992 ms
4 be28.clmkohpe01r.midwest.rr.com (65.29.1.44) 17.167 ms 15.355 ms 15.760 ms
5 ae-9-0.cr0.chi30.tbone.rr.com (107.14.19.16) 26.169 ms 25.484 ms 29.174 ms
6 bu-ether15.lsancarc0yw-bcr00.tbone.rr.com (66.109.6.227) 73.940 ms 75.105 ms 74.925 ms
7 ae0.pr1.lax10.tbone.rr.com (107.14.19.50) 70.985 ms 74.569 ms 72.387 ms
8 66.109.9.103 (66.109.9.103) 70.669 ms 71.687 ms 98.918 ms
9 e2-1.r1.ph.hwng.net (209.197.0.22) 81.424 ms 81.033 ms 97.435 ms
10 ve1023.ar1.ph.hwng.net (xxxx) 84.184 ms 81.019 ms 79.149 ms
11 * * *
12 * * *
13 * * *
14 *
Re: Slow Loading? [Re: Biggerfoot] #608145 12/07/13 06:27 PM
neil Offline
Neil Ticktin
Neil Ticktin
Since I can't see the end of it (it timed out), how about a ping:
ping forums.AppleCentral.com
from within Terminal.app if you want.
Thanks!
Neil
Re: Slow Loading? [Re: Biggerfoot] #608150 12/07/13 07:40 PM
I invented modding!
I invented modding!
Ping has started…
PING hostgator.xplain.com (142.4.22.215): 56 data bytes
64 bytes from 142.4.22.215: icmp_seq=0 ttl=48 time=89.867 ms
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
Request timeout for icmp_seq 6
Request timeout for icmp_seq 7
Request timeout for icmp_seq 8
--- hostgator.xplain.com ping statistics ---
10 packets transmitted, 1 packets received, 90.0% packet loss
round-trip min/avg/max/stddev = 89.867/89.867/89.867/0.000 ms
Re: Slow Loading? [Re: Biggerfoot] #608156 12/07/13 10:16 PM
Reboot Offline
Since it was okay on the phone, to see if it's something with your ISP's DNS servers, in your DNS servers in Network preferences add 8.8.8.8 and 4.2.2.3. Google public DNS, and Level 3 Public DNS.
Maybe your ISP's DNS servers are slow to update changes.
Page 1 of 2 1 2
