No problems here. Try clearing your Safari cache, but more than likely it's just a hiccup in your route to the server. If you have a phone to try it on try it using your phone data, not your home wireless. If it's okay on the phone then it's something with your internet connection.
Biggerfoot
I invented modding!
Seems to work okay on my phone connection. The second or third time on network connection, it was speedy and then would hang again. I will see if it clears up as it is better as it would not even load yesterday.
neil Neil Ticktin
Loc: Westlake Village, CA
If you see slow loading, and you are able to run a traceroute between you and the server, that would be good. Typically, when the reports are not widespread they are often an Internet connectivity issue … not necessarily on your end, but in between where the server is and you.
Biggerfoot
I invented modding!
Took me a few minutes to find the Network Utility in 10.9!
traceroute: Warning: http://forums.applecentral.com/ has multiple addresses; using xxxx traceroute to http://forums.applecentral.com/ (xxxxx), 64 hops max, 72 byte packets 1 10.0.1.1 (10.0.1.1) 2.025 ms 0.408 ms 1.225 ms 2 cpe-xxxxx-1.cinci.res.rr.com (xxxxxx) 11.478 ms 9.829 ms 11.957 ms 3 be21-1081.blasohdp01r.midwest.rr.com (65.25.146.77) 15.764 ms 12.772 ms 16.992 ms 4 be28.clmkohpe01r.midwest.rr.com (65.29.1.44) 17.167 ms 15.355 ms 15.760 ms 5 ae-9-0.cr0.chi30.tbone.rr.com (107.14.19.16) 26.169 ms 25.484 ms 29.174 ms 6 bu-ether15.lsancarc0yw-bcr00.tbone.rr.com (66.109.6.227) 73.940 ms 75.105 ms 74.925 ms 7 ae0.pr1.lax10.tbone.rr.com (107.14.19.50) 70.985 ms 74.569 ms 72.387 ms 8 66.109.9.103 (66.109.9.103) 70.669 ms 71.687 ms 98.918 ms 9 e2-1.r1.ph.hwng.net (209.197.0.22) 81.424 ms 81.033 ms 97.435 ms 10 ve1023.ar1.ph.hwng.net (xxxx) 84.184 ms 81.019 ms 79.149 ms 11 * * * 12 * * * 13 * * * 14 *
Biggerfoot
I invented modding!
Ping has started…
PING hostgator.xplain.com (142.4.22.215): 56 data bytes 64 bytes from 142.4.22.215: icmp_seq=0 ttl=48 time=89.867 ms Request timeout for icmp_seq 1 Request timeout for icmp_seq 2 Request timeout for icmp_seq 3 Request timeout for icmp_seq 4 Request timeout for icmp_seq 5 Request timeout for icmp_seq 6 Request timeout for icmp_seq 7 Request timeout for icmp_seq 8
--- hostgator.xplain.com ping statistics --- 10 packets transmitted, 1 packets received, 90.0% packet loss round-trip min/avg/max/stddev = 89.867/89.867/89.867/0.000 ms
Since it was okay on the phone, to see if it's something with your ISP's DNS servers, in your DNS servers in Network preferences add 8.8.8.8 and 4.2.2.3. Google public DNS, and Level 3 Public DNS.
Maybe your ISP's DNS servers are slow to update changes.
