Remove defective app from iCloud/iPad? #607842 11/30/13 08:35 PM
H
haakon73 Offline OP
n00b
n00b
H
While backing up my iPad to iCloud one app transferred only the app icon. I restored from that backup and now I have the icon with the waiting message but the cloud thinks it is downloaded. I can open it from the cloud list but not directly from the iPad icon. How can I delete the icon from my iPad and rue download it. The normal "wiggly icon " delete method has no X in the corner
Re: Remove defective app from iCloud/iPad? [Re: haakon73] #607843 11/30/13 09:12 PM
Reboot Offline
Did you reboot the phone?
Re: Remove defective app from iCloud/iPad? [Re: Reboot] #607844 11/30/13 10:15 PM
H
haakon73 Offline OP
n00b
n00b
H
Yes, What worked was to delete from settings/general/usage/storage which converted the icon to a generic icon which I could then delete. I'm redownloading now and things seem normal. Thank you for your help
