When you can CHOOSE Any Decal You Wish --- Protected by A Clear Silicone TPU Cover TPU, also known as thermoplastic polyurethane, is more cut and tear resistance over rubber. It is abrasion resistance, and has a high degree of transparency. Compared to silicone skins, this skin is stiffer to the touch, but remains flexible.
Shop Carefully: The decals are for iPhones 3,4&5 Some Cover the Front & Back.. others don't...
The Cases are from a different Seller: also for iPhone 3,4,&5 AND Made of Different Materials -- from Soft Silicone to the TUFF TPU & some Hard Plastic ... and different colors.
My New iPhone3Gs (2yrs ago) At the time the decal cost $25, the frosted iSkin was $25
2 1/2 years later and it looks exactly the same! I could pry off the TFU iSkin, Peel off the decal and sell the phone as "Pristine" tomorrow... ( IF I wanted to --- I don't )
MacBozo Nut Dood
My iPhone 4 is encased in an Otterbox. Unless something penetrates that barrier, my phone will still be pristine when I think about upgrading next June.
If it's a CLEAR OtterBox you can still add a Decal. Otherwise I wouldn't recommend them since I'd reckon they'd peel off under moderately rough handling.
While perusing their iPhone Decals I noticed that SOME of the decals that covered Both Back & Front..some also had the same pattern on the Start-Up & the App Screen.. purdy kewl!
And I pretty much took for granted that it was pulled-off via a simple Wallpaper Screen Image, but for the hellovit, I contacted the dealer...
Dear Sirs, I see that some of your iPhone Decals show the FRONT Decal wherein the Picture on the Decal continues on the open iPhone, where you can see the decal picture & the iPhone Buttons ...?
How is this accomplished?
Thank You In Advance
He got back to me within the hour:
hello, Ok this is done via the internet ..After the purchase we can send you an email that is called a Wallpaper image....It is the same image as the rest therefor it looks like the screen is also covered.. Its fairly high tech and we offer this at zero cost....
