I like the new Radio feature in iTunes11.1. Works fine on my iMac with OS 10.8.5, but the new Radio option doesn't show up in iTunes 11.1 on my MacBook with 10.6.8. Curses,foiled again!
I tried to download Mountain Lion 10.8.5 and was informed it wasn't compatible with my computer. Curses, foiled again! Apple says that 10.6.8 is required and that's what it has.
According to headquarters: (to run 10.7) Your Mac must be one of the following models: iMac (Mid 2007 or newer) MacBook (Late 2008 Aluminum, or Early 2009 or newer) MacBook Pro (Mid/Late 2007 or newer) MacBook Air (Late 2008 or newer) Mac mini (Early 2009 or newer) Mac Pro (Early 2008 or newer) Xserve (Early 2009)
Edited by drjohn (09/23/1304:33 AM)
Thank you, but it's still no go. And it's a 2,1 running 10.6.8 that is fully updated.
Model Name: MacBook Model Identifier: MacBook2,1 Processor Name: Intel Core 2 Duo Processor Speed: 2 GHz Number Of Processors: 1 Total Number Of Cores: 2 L2 Cache: 4 MB Memory: 1 GB Bus Speed: 667 MHz Boot ROM Version: MB21.00A5.B07 SMC Version (system): 1.13f3 Serial Number (system): 4H706R11WGL Hardware UUID: 00000000-0000-1000-8000-0019E33607BC Sudden Motion Sensor: State: Enabled
It can't run Mountain Lion 10.8, but it can run Lion 10.7 which will give you Radio in iTunes. Follow the instructions in the link below to get Lion. You'll have to call Apple, give them $20, then they'll send you a redemption code to redeem in the Mac App Store.
