iCloud iWork Beta #599776 08/01/13 06:25 PM
Acumowchek Offline OP
Is this thing on?
Is this thing on?
Apple sent an invitation to try iWork in the cloud last week.
I gotta say, I'm very impressed! It's pretty basic, but the speed is amazing.
Thanks for everything, Apple!
Re: iCloud iWork Beta [Re: Acumowchek] #599777 08/01/13 06:41 PM
J
John Rougeux Offline
Member # -1
Member # -1
J
What? They let you work on a beta program? How dare they!? laugh ha
So I'm not so sure about this...it only works online? What happens if you are offline?
Re: iCloud iWork Beta [Re: John Rougeux] #599778 08/01/13 07:01 PM
Is this thing on?
Is this thing on?
How dare they!
I know, right? wink
You can save documents to your computer to work offline, and load them back into the cloud later (in theory).
The cloud version is so stripped down in functionality, I wouldn't recommend that work flow.
I'm not sure how this compares to iWork on iOS devices, never used it.
