• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mac » Hardware » Third and Forth Hard Drive Bays Not Showing Up
Page 2 of 3 < 1 2 3 >
Topic Options
Hop to:
#598734 - 07/17/13 04:58 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: NucleusG4]
Biggerfoot Offline
I invented modding!
It was this drive that I picked up for $50 on sale. It is a 6.0 and not 3 but it did work fine in bay two hence being able to format it.
http://www.newegg.com/Product/Product.as...ntent-_-text-_-
Top
#598735 - 07/17/13 04:59 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: NucleusG4]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
Can you swap connectors on the mobo from the working ones to the non-working ones to see if its a mobo issue... or the bays?
Seems unlike two bays would go out... right next to each other... either a connection... or a bad mobo?
http://davidbearphotography.com/
Top
#598736 - 07/17/13 05:03 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: Biggerfoot]
Reboot Online   content
Loc: Columbus OH
If all of the cables are tight on both the logic board end and the where the drive sleds plug in from what I've been reading it's a bad logic board, they call it the backplane board too.
It seems like a common problem.
You can get an internal SATA card for around $30, Rocket620A. Macmall has them so they are OS X compatible, but OWC has them cheaper. I don't know if the wiring you have can be re-routed or if you can use the cables that come with it to attach to the back of the sled holder. Supposedly this one works in a Mac Pro. Not sure if it's bootable tough.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#598738 - 07/17/13 05:31 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: Reboot]
Biggerfoot Offline
I invented modding!
I did not even think about SATA card! I have one in my QuickSilver that may work in the PCI Express slot.
The hard drives slide into the connectors on the logic board though. I will have to look and see I can turn the hard drive around and have the connections from the card.
Here is an image of what the logic board connection looks like (ODD-the two connectors on the upper right hand side. There are just two so I am guessing each one is for two bays. I did not try switching them...have to take the fan out for that.)
Here is where the HD sled slides in. On the blue circuit board on my third bay there is a magic marker mark:
Top
#598744 - 07/17/13 06:53 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: Biggerfoot]
Loc: Columbus OH
The Quicksilver card won't work. I'm also wondering about how you'll get power to the drives. The connectors on the PCI E card are for data.
Instead of having to turn the hard drives around backwards, I wonder if you can remove the two screws on the connectors at the end of the sled holder. Do those cables come off, or are they soldered into that connector.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#598745 - 07/17/13 06:55 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: Biggerfoot]
Loc: Columbus OH
BTW the card comes with data cables, I don't believe it comes with power cables.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#598753 - 07/17/13 07:29 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: Reboot]
Biggerfoot Offline
I invented modding!
The power is a good question. The QuickSilver card has a data and a power cable. The power cable connected to the old style IDE power connector. It looks the newer cards have the place for the data and power cable. I know for the external PCI card, I am thinking the data for the newer cards would plug into the logic board from on the two empty connectors marked ODD_SATA. The other two empty connectors to their right is were my video card power plugs in.
I am not sure what is behind the connectors for the sled.
Another card:
http://eshop.macsales.com/item/NewerTech/MXPCIE6G2S2O/
Top
#598755 - 07/17/13 07:55 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: Biggerfoot]
Loc: Columbus OH
That card is external SATA only, eSATA
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#598757 - 07/17/13 08:03 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: Reboot]
Biggerfoot Offline
I invented modding!
ah...yes it is...just assumed.
Top
#598758 - 07/17/13 08:07 PM Re: Third and Forth Hard Drive Bays Not Showing Up [Re: Biggerfoot]
Loc: Columbus OH
ODD = Optical Disc Drive. From what I've read it will work with HDs, but they are not bootable is all.
So if you could get power to the 3rd HD, along with a SATA data cable on one of the ODD SATA connectors you may not need a card.
Will the cable from the 3rd sled running to the logic board stretch to the ODD SATA connector? I wonder if the SATA connector is bad on the board, or if it's not getting power to the drive, can you hear the new drive spin up or see a light on it?
Maybe get SATA data and/or power extension cables?
Just some thoughts.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.051 seconds in which 0.034 seconds were spent on a total of 14 queries. Zlib compression enabled.
